This is a script command and operates only in scripts or on the command line when scripting is enabled with the following command: enable cli scripting {permanent}.
Deletes a variable.
varname | Specifies the name of the scripting variable to be deleted. |
N/A.
The format of a local variable (case insensitive) is: $VARNAME.
delete var x
